Need easy instructions on changing engine coolant
Old May 12, 2001 | 08:55 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Could someone please give me easy instructions on flushing and changing my engine coolant? I have a big air pocket and I cnt get rid of it so I'm having to get the whole system flushed.
Thanks for the help
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old May 12, 2001 | 09:14 AM
Vader's Avatar
RMK,
Start and warm the engine with the radiator cap removed. This will allow entrapped air to escape more easily. Regardless of how much air is displaced by this procedure or any other, you will have to monitor the cooling system level for several days.
The problem is often not entrapped air in voids in the cooling system, but the fact that most water contains air. Unless you refilled the system using deaerated water, the air in the water will liberate when the water is heated to about 170°F. The freed air will form more pockets of air in the system until they are vented.
You can reduce this by using water from a garden hose as opposed to that from a faucet with an aerator. You can also pre-boil the water to eliminate most air. Allow it to cool, then mix it with the anitfreeze. You will still have to monitor the coolant level, but will probably have lees to add.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
