Cam lift Question.
Old May 12, 2001 | 12:32 AM
nelliesIroc's Avatar
Cam lift Question.
I hav recently purchased a set of vortec heads and I was planning on running a comp cams extreme energy 268 cam but I am wondering if I will need to put new springs in because the likt on the exhaust side is .48 and the max on the stock springs is .48 as well. Has anyone had any problems running this much lift with these heads? or have any suggestions?
Old May 12, 2001 | 01:31 AM
Joseph@SDSC's Avatar
The vortec heads as they come from GM are supposed to be able to only handle .450" lift. But...I've heard of ones that have run up to .490", not sure if they were aware if there was any problems.
-Joseph
ASE Master Automobile Technician
Scoggin-Dickey Chevrolet
1967 Camaro (Vortec Heads, GM Vortec Intake, ZZ4 roller camshaft) --- Planning T-56 Install in the near future
1992 Firebird (Weiler Vortec Heads, LT4 Hot Cam, GM Vortec Intake, 3000 Stall, 3.73's, Auburn Posi)
Old May 12, 2001 | 09:48 AM
Vader's Avatar
Wooe, Nellie!
Since you should already be planning to machine the spring seats to a larger diameter (for the larger springs that you are going to have to install) you might as well trim the tops of the valve guides for clearance while you are there.
So what's the question?
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 12, 2001 | 09:52 AM
ede's Avatar
ede
what Mr. Vader said. i never run stock springs or retainers with an aftermarket cam.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 9, 2015 10:01 AM
TheExaminer
Sep 6, 2015 11:40 PM
Ian Irvine
Sep 4, 2015 08:08 AM
masonta
Sep 1, 2015 06:40 PM
