Maf help!
Old Sep 17, 2004 | 05:30 PM
Mesix's Avatar
Car: '87 Trans Am
Engine: L98 (Corvette)
Transmission: M5
Maf help!
I posted this in electronics, too.
Mods can delete whichever doesn't get replies.
One of the (filament?) wires came loose
I'm getting a check engine light now
CAN IT BE REPAIRED? HOW? Solder? What? I'm freaking out
My car starts without it, but can I drive it? I can't afford a new MAF!
Old Sep 17, 2004 | 09:36 PM
onebinky's Avatar
It's junk, time for a new one.
You can try unplugging it for the time being. Should run and drive, but you'll get worse mileage and drivability with it.
Try the boneyard if you need one for cheap...
Old Sep 18, 2004 | 10:44 AM
Vader's Avatar
I actually repaired a MAF hot wire on a Bosch MAF from my '86. It took me several days to find a supplier for the 0.0041" platinum wire, and that alone cost about $3.00/inch. The connections cannot be soldered, since the frequent burn off function turns the wire incandescent, which would melt away any solder at the joints and render the MAF useless. The ends are crimped and resistance welded, much like a heating element in a toaster. I accomplished that with a small brass clamp and a 48VDC power supply to finish the welds. You will need small tools, a good eye (or loupe), and near surgical skill to assemble the hot wire into place for welding.
When I got it all back together, it worked, but was not in tolerance. In other words, the output voltage was incorrect for a given measured amount of intake air. I'm guessing that the alloy I used was slightly different than what the Germans used, thus the resistivity and heat rejection characteristics of the wire were different. It was a good learning experience, however, and I got a good look at how the Bosch analog MAF functions, both physically and electronically. I spent about a week educating myself on hot wire sensors.
That, of course, was all done after I had replaced the original MAF with a new one. Unless you have a source for the correct platinum wire, and a lot of patience, you might have to bite the bullet and find a replacement sensor.
Old Sep 18, 2004 | 02:17 PM
onebinky's Avatar
That's pretty cool, I didn't realize that was possible. Do you remember where you got the platinum wire from?
Old Sep 19, 2004 | 07:08 AM
Vader's Avatar
Yes, and in digging up the details, I discovered that I was mistaken. It is AWG 41 wire, and is 0.0028", not 0.0041". It was a Pt/Ni/Cr alloy called Alloy 60, AWG41 @ 20°C = 7.653062 ohm/ft., Melting point 1635°C.
And it was more like $3.00/ft, not $3.00/inch.
Climco Coils Co. -- Morrison, IL
Old Sep 19, 2004 | 11:49 AM
onebinky's Avatar
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
