89 IROC runs better at 30 degrees advanced vs 6 degress stock..
Old May 12, 2001 | 01:36 PM
EO273KiD's Avatar
Ok, I got mad and set my timing on my 89 IROC back to twenty eight degrees advanced timing as that was what it was at before i went to fix it and set it back to stock... after setting it to 6 degrees i had an over all loss of performance... what gives?
Owner of a 1989 IROC-Z Camaro, a.k.a. "The Babe Magnet". Painted a cheap metallic blue that chips off all too easily and covers over the IROC-Z decals on the doors, also has non-leaking T-tops, ps, pw, power rear hatch, working A/C. Mods: SLP intake runners, gutted MAF sensor, adjustable fuel pressure regulator, modified air spoil, 3.27 posi rear end.
Broken stuff: rear spoiler brake light, driver side lock, power antenna, tilt steering, rear end bushings, cracked passanger side ground effect, washer fluid tab, leaking exhaust and a rotted through muffler that sparks when the car bottoms out while driving like any 17 year old does.
Old May 12, 2001 | 04:35 PM
Guest
Guest
Posts: n/a
Are you disconnecting the tan wire before setting the timing?
Old May 12, 2001 | 10:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
And I'd verify TDC vs. the timing mark and tab...balancer may have slipped.
BlueIroc-Z
Jun 9, 2019 03:22 AM
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
Irocohio
Aug 12, 2015 08:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
