when advancing timing should i increase fuel pressure?
Old May 12, 2001 | 03:54 PM
rondubbs's Avatar
if so, why/why not?
teach me , my fellow thirdgen brethren.
1988 GTA Trans Am 350tpi: 47k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, homemade cold air induction, flux capacitor, driver side floor mat removed
[This message has been edited by ron rizzotti (edited May 12, 2001).]
Old May 12, 2001 | 09:41 PM
rondubbs's Avatar
bttt
Old May 12, 2001 | 10:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes and No (great reply, huh?), depends how things cuurently are, but you can mask some detonation/preignition with more fuel, but you could also be loosing power as well, by running too rich.
Problem with this, is most likley, only WOT pinging will be affected, part throttle pings will probably still be there.
It's all in the tuning with your mods, as you make changes, read the plugs, to see what's going on in the cylinders, monitor the O2 voltage at the least, or beg/borrow/steal a scanner for the INT and BLM counts, to see what the ECM is trying to do with what it has, and monitor for any knock counts too.
Old May 12, 2001 | 11:09 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
It all depends, these are some of the things you play with while tuning your combo. Some cars like 42 psi and 8º, some 38 psi and 10º some 50 psi and 4º, see what I mean? These are just some variables you use to extract as many ponies as possible from your combo. This is why those that take their sweet time to play with this stuff always go faster.
"To provoke dreams of terror in the slumber of prosperity has become the moral duty of literature"
-Ernst Fischer
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
