454 misifres bad, can't find the cause......
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
I'm working on my brothers truck, a 80 chevy with a 454 that he just put a eldelbrock performer plus cam/manifold package, headers and a valve job.
Ever since he did everything it had developed a miss and runs really rough and has no low end power.
I just did a tuneup with new cap/rotor, plugs and wires but it still has a bad miss and sometimes pops out of the exhaust when you rev it. Tried rebuilding the carb(q-jet) but it didn't help either. It's running very rich as the plugs were dark and a little wet looking, and you can just smell how rich it is by the exhaust smell. Went to adjust the idle mixture screws but they did nothing at all, was able to screw 'em all the way in and it still ran
Did a compression check and got these numbers:
#1-135lbs
#2-135lbs
#3-140lbs
#4-145lbs
#5-140lbs
#6-125lbs
#7-135lbs
#8-125lbs
I see a couple cylinders are low but it should run better than it is.
Any suggestions on what I can try next?
Of course I wanted to try a different carb but since all my vehicles are injected I sold all my holleys and q-jets
#1-135lbs
#2-135lbs
#3-140lbs
#4-145lbs
#5-140lbs
#6-125lbs
#7-135lbs
#8-125lbs
Engine: LS1/L98
Originally posted by ede
compresson is fine. try running the valves, setting timing, checking for vacuum leaks
Engine: LS1/L98
Well, the cam was installed straight up recently with a new double roller set so I'm positive that's not my problem.
Boy, this is driving my nuts
Guess I'm gonna pull the carb and go through it, since it's not right either. Maybe it's flooding the engine out
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Maybe the distributor is off 180* or so. Maybe you got a couple plug wires crossed? check that the valves are adjusted properly.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Just to add to what was already said, maybe your choke stuck open/closed?
Engine: LS1/L98
I think I have narrowed it down to a bad carb, went through everything and readjusted everything and went through the carb again and it only misses now when it idles for a while, like it's loading up with fuel, then if I rev it for a few seconds it clears up. Carb's been rebuilt twice so it must be a internal leak in it somewhere.
Gonna try and find a carb I can use to try on it before I buy one.
Thanks for the suggestions.
