code 43...
code 43...
90 camaro 305 tbi. code 43-low ESC voltage. tried a map and an IAC but to no avail. the computer also reset itself before i took it in and displayed no codes even though i know it set the code that morning prior...what could it be?
Car: 91 camaro
Engine: 383
I had this problem briefly when my knock sensor wire got a little too cozy with one of my plug wires. Guess the plug wire was inducing a voltage in the knock sensor circuit or something like that. This one's a pretty easy visual check.
Car: 91 camaro
Engine: 383
The knock sensor should be in the passenger side of the block, towards the back. It will have two wires going to it, but I don't know what color they are. Are you getting the code all the time, or just every once in a while? And is the car running bad or do you just have a code?
