Car drops a cylinder under load.
Old Sep 19, 2004 | 08:55 PM
Snapshot's Avatar
Car: '89 RS
My '89 RS has a 305 TBI that recently started to miss while under load at low RPM(<2000). Three years ago I put a Crane multiple spark module on it (HI-8, I think its called?), and its run fine until about a week ago. It now seems to drop a cylinder going uphill, or when trying to accelerate too quickly, occasionaly backfiring through the intake. It idles fine, and above 2000RPMs the engine accelerates smoothly, but for a couple of hundred RPM it shakes and stutters. I've replaced the spark plugs, the cap and rotor, and the ignition module on the distributor, but the problem hasn't gone away. Twice in the past week it has refused to start, it would turn over but not fire, and when I let off of the ignition it would stop and then give one last spark after about a second of dead time. After a couple of minutes it would start, but ran rough for a few seconds before the idle smoothed out.
I'm not sure what the problem is. I thought it was in the ignition side of things, but now I'm not so certain. I suppose it could be the ignition box, or maybe the computer itself, or I could be completly wrong. If anybody has any ideas, I'd sure like to hear them.
Old Sep 19, 2004 | 08:58 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
sounds like it could be your fuel. check the pressure in the line.
Old Sep 19, 2004 | 09:10 PM
Snapshot's Avatar
Car: '89 RS
Wouldn't it run roughly at idle if the fuel pressure was low?
Old Sep 19, 2004 | 09:14 PM
ljnowell's Avatar
Not necessarily.
Old Sep 19, 2004 | 09:25 PM
sellmanb's Avatar
Car: '86 Berlinetta
you replaced plugs, cap and rotor already, why not the plug wires?
I agree though, it sounds like a fuel problem. Check your fuel filter before you go out getting a new fuel pump
Old Sep 20, 2004 | 08:32 PM
Snapshot's Avatar
Car: '89 RS
The distributor hold down bolts had come loose. Timing was 12* advanced. Backed it back to 4* and it seems to run fine now.
Old Sep 20, 2004 | 09:07 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
That'll do it.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
bryan623
Aug 10, 2015 11:33 AM
Kaweh
Aug 9, 2015 02:54 PM
