EGRRRRRRRR!
Old May 12, 2001 | 06:49 PM
speedlvr's Avatar
EGRRRRRRRR!
The egr valve is supposed to be closed at idle and w.o.t. and opened between the two exremes, right? Mine stays closed all the time whether in park, nuetral or in gear. Every once in a while I get a code 32. But my main reason for doing a battery of tests on the egr and it's components is to see if it was inoperative and contributing to the knock I get sometimes. The valve opens with a hand held vacuum so I know the diaphragm is good. There is 14 inHg. vacuum at the throttle body port. Neither hose leaks. The solenoid opens with voltage applied to the terminals. A test light lights up when hooked up to the solenoid harness. Why doesn't the valve ever open when it is supposed to? Could it be that it's burning so clean that there's no need for it? Thanks.
Old May 13, 2001 | 12:05 AM
speedlvr's Avatar
Nobody knows what the deal may be?
Old May 13, 2001 | 01:11 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
hey speed....this should help ya....
http://www.racer-x.f2s.com/proc/egrlearn.htm
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>I have experience...unfortunatly,its a result of bad judgement.<HR></BLOCKQUOTE>
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Old May 13, 2001 | 11:09 AM
speedlvr's Avatar
Excellent information! Thank you.
