Idle Air Intake Valve ? ?
Old Sep 20, 2004 | 09:32 AM
Zimmerman's Avatar
When I come to a stop at a stop sign/light/parking, my car goes into idle. After a little bit, it chugs, and chugs, and dies. I believe it is my idle air intake valve that is dirty. Just how can I get to it to clean it? When stopped, if I push on the gas pedal just the smallest amount while applying the brake, my car won't die.
Old Sep 20, 2004 | 09:36 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
it's called the IAC it could be gumbed up. which would make sense cause if not enough air gets by the baldes then it will chug and struggle. but when you give it gas more air is forced bast the baldes and it runs fine correct?? check that out. thats my .02$ have fun
Old Sep 21, 2004 | 09:45 AM
Zimmerman's Avatar
Where is it?
Thanks for the tip, that's what I thought it was also.........but where is the IAC ?
That's my problem, I'm not sure where it is.
Old Sep 21, 2004 | 09:52 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Re: Where is it?
It is under the throttle body, it has a 4 wire harness connecting to it.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
89mulletbird
Aug 12, 2015 07:08 PM
Jake_92RS
Aug 11, 2015 10:39 AM
