Need upgrade help
Old Sep 20, 2004 | 11:57 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Need upgrade help
read the profile and sig for current setup. i want to start getting inside the beast and change things up like intake man. heads, cam, etc. but it's only a 305. Is it really worth modding it out more or should i get the 350 and bore it to a 383 and then start dumping the money. I don't wanna put too much more money into the 305 if i'm not gonna get that good of end results. any suggestions. I am in college so money is tight right now too.
Old Sep 20, 2004 | 12:35 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
a 383 is a 350 block with a 400 crank but any way.. yes youd be much better off putting money into a 350... but for now simple bolt ons like headers and such are fine because you can use them on a 350
Old Sep 20, 2004 | 12:44 PM
trueburton's Avatar
thanks for the clarification, i thought a 383 was a 350 with a 400 crank and bored .040 ?
Old Sep 20, 2004 | 01:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
A 383 is a 4.030" bore with a 3.75" stroke. (a "350 block" bored .030" over, and a 3.75" stroke). A virgin 4.00" bore bya 3.75" stroke yields a 377.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
