92 Z28- Fuel Pump not kicking on
Old Sep 20, 2004 | 08:04 PM
BrianI's Avatar
Sometimes the fuel pump won't kick on and the check engine light comes on. He has to turn the key back and forth a few times before it will pump kicks on. Do these cars have fuel pump relays?
Anyone have this problem before? Its a 350 tune port
Old Sep 20, 2004 | 09:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes, they do have fuel pump relays.
If the check engine light is on, take a trusty paperclip and jam one end into the "A" terminal, the other into the "B" terminal on the ALDL port. Those are on the top row, the farthest 2 on the right hand side. (The ALDL is inside the car. If you peer under the steering column, by the knee bolster, you will see a port, that looks like it should connect to something. That's the ALDL). Turn the key to the "on" position, without starting the car. You will see code "12" flash 3 times, the SES light itself will blink. blink *pause* blink blink represents code 12. That itself means you are entering diagnostic mode. Any code blinked thereafter is a trouble code. Make note of it. Once you get the code, go <A HREF="http://www.gmtips.com/3rd-degree/dox/tips/ecm/codes/code-01.htm">HERE</A> and cross reference. This gives you an iidea of where to start looking. Keep in mind, the SES DOES illuminate for a few seconds as a test when you first turn the car on, so make sure that what you are seeing is not that test mode.
Since the pump does eventually run, just after a few turns, I would suspect the relay or its wiring is at fault.
The fuel pump relay itself is under the hood, on the firewall, by the brake booster. You should see a strip of 3 or so relays. I'm not certain, but I want to say the middle one is the fuel pump relay.
Old Sep 20, 2004 | 09:19 PM
BrianI's Avatar
excellent info!! I'll tell him about it, thanks
Old Sep 21, 2004 | 10:11 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
