Bad Starting--Bad Idling??
Old May 10, 2001 | 06:41 PM
88 IROC BOB's Avatar
OK, not only is it starting like crap it is now idling like it too.
To get you up to speed when I turn the key "on" the relay doesn't click at all and fuel pressure doesn't build (it used to do this) and I get a code 54. I've changed the relay and still the same problem. Is this a problem with the ecm? When it does fire after extended cranking it really smells like gas BAD! I've had the injectors cleaned but it really seems like I got a leaker.
Also lately when it is idling in gear the revs surge from 500 to 800. Don't know if its coincidence but it seems to have started doing this shortly after the convertor install.
Any ideas?
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old May 13, 2001 | 08:01 PM
xxx3man`
Sep 23, 2015 10:37 PM
mike_c
Aug 27, 2015 04:32 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
