platigauge tolorances
Old Sep 23, 2004 | 07:04 PM
NoUseAbleNames's Avatar
what is the tolorance on a crank and rods if i check them with a platigauge??
Old Sep 23, 2004 | 07:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Plastiguage is a joke. If you are at all serious about tolerances, use the proper tools. Snap gauges, mikes, and dial bore gauges are all things I have used in the past.
And what clearances on the crank and rods are you looking for? Thrust? Bearing (rod and mains) tolerances? Rod side clearances?
Old Sep 23, 2004 | 07:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Don't waste your time with plastiguage. Its nowhere near accurate enough for use on anything.
Get real tools to measure tolerances. PLEASE!!!
Old Sep 23, 2004 | 09:14 PM
i was going to use them to measure my main and rod bearing as i dont have calipers or any of that stuff. i got a pack of them in a rebuild kit and it doesnt say what was a acceptable tolorance. so if i get a set if calipers for the crank. what #s am i looking for???whats bad whats ok and whats good?
Psycho_91Camaro
Sep 6, 2006 02:25 AM
injdinjn
Firebirds Wanted
Aug 8, 2006 02:52 PM
Psycho_91Camaro
Southern California Area
Jul 24, 2006 12:47 AM
injdinjn
Firebirds Wanted
26
Jun 13, 2006 08:07 PM
sniper_dts
Feb 6, 2006 10:08 PM
