Speedo cable attachment Question
Old May 14, 2001 | 01:58 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey I am in the process on installing my new motor and I began to hook up my tranny and I found that my speedo part that is on the Tranny is striped (the male end)
Can I buy a new one or what can I do.
Brian Felts
Old May 14, 2001 | 05:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If this is the plastic gear that's damaged, then yes, you can buy a new one. They're about $10 at the GM dealer. You'll need to know your gear ratio and tire size, or your rear end option codes, to order the right one. If you're lucky they'll be able to recognize it by # of teeth and color, but don't count on it.
You should find out why it stripped and fix it; usually a cable that is dry of lube and binding, or a bad cruise regulator is the cause.
ICON Motorsports
Old May 14, 2001 | 05:54 PM
NO not the gear its the piece that the speedo cable screws on to!!! I have no idea about this one.......HELP ME!!!!!!!!!
Brian
Old May 14, 2001 | 06:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AFAIK you can get that at the dealer too... in fact, the replacement one for the T5 is steel, compared to the OE one which is chinesium (translation: cheapest stuff that won't dissolve in gear lube) which is probably why it stripped in the first place. Don't know about the auto version though.
ICON Motorsports
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
