Intake Gasket???
Old Sep 24, 2004 | 10:37 PM
92GTA's Avatar
Intake Gasket???
When I removed my stock intake base I saw that the shop who had done my head gasket 5 years ago used like a freakin TON of gasket maker on the front and rear of the block to seal the intake.
Isn't there like a rubber gasket you can buy to go there rather than use gobs of gasket maker? If so, does anyone have a P/N or a proper name for what this gasket is called so I can get them from CarQuest tomorrow....
Thanks!
Old Sep 24, 2004 | 11:06 PM
ljnowell's Avatar
Actually if you buy a gasket set, it will come with them. But dont use them. The best way is to seal the ends with a nice healthy bead of silicone, and then a little glob in the corners. This is how the shop that replaced yours did before.
Old Sep 24, 2004 | 11:15 PM
92GTA's Avatar
Yeah I bought the GM gasket set and it didn't have that or the thermostat housing gasket.
So a good bead of gasket makers is the best? Hmmm....
Old Sep 24, 2004 | 11:58 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
you need to run a bead of gasket maker @ 1/4 of an inch on the front and rear seating areas of the intake on the block and put a good blob of it where the actual intake side gaskets meet the front and rear on each side and you will not have a problem with it
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
