How do I do this in Desktop Dyno???
Old Sep 26, 2004 | 11:41 PM
92GTA's Avatar
Ok stock specs for my LB9 are this:
Piston Down Bore @ TDC: 0.045"
Deck Volume @ TDC: 8.21cc
I'm going from stock pistons to JE pistons with a -12cc dome. How do I enter that into Desktop Dyno? It wants a new "Piston Down Bore @ TDC" and is asking for a new variable called "Volume Above Piston" to calculate the new "Deck Volume @ TDC".
What do I enter?
Old Sep 27, 2004 | 12:36 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You use the compression ratio calculator in DD2000. You enter those parameters and head volume.
Old Sep 27, 2004 | 12:44 AM
92GTA's Avatar
I'm using Dyno2003, here are my screen shots:
The top one is stock, the second is what I need to fill in and I don't know what values to use
Old Sep 27, 2004 | 12:14 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
For the Pistion has dome, dish, or valve relief...
4 - Piston down from TDC is the distance from the deck of the block to the highest part of the piston.
5 - Volume above piston is the volume of water that you can pour into the area above the piston and have it level with the block deck.
So for your car...
Lets say your the distance from the highest part of the piston piston in 0.1 in below the deck height. So, 0.1 goes into the #4.
If you have a burette go fill the area above the piston with water and put that number in #5.
If you don't you can also calculate it.
Lets break the area above the piston up into to volumes the volume that is above the piston if it were flat (volume #1) and the recessed volume of the piston (volume #2).
To calculate volume number one use the following formula where #4 is the distance you entered in DD's #4:
#4*0.785398*(your bore)^2 = volume in in^3
since 1in^3 = 16.387cc we need to multiply the above answer by 16.387.
Take this volume and subtract it from the dome height of your piston.
For your car....
lets sat #4 is .1
.1*0.7853982*(3.766)^2 = 1.11391in^3
Convert this to cc
1.11391*16.387 = 18.254 cc
Next,
18.254 - (-12) = 30.254cc
30.254 goes in #5
So, your car would have a CR of 9.23.
David
Old Sep 27, 2004 | 01:01 PM
92GTA's Avatar
Thank you very much for taking your time to walk me through that :hail:
Alex
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
