underdrive pulleys and smog removal belt length
Old Sep 27, 2004 | 12:52 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
When using underdrive pulleys you need a shorter belt, correct? With the smog pump removal you also need a shorter belt, correct? when both mods have been applied to your car what length belt is then required?
Old Sep 27, 2004 | 04:31 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Smog Pump removal makes you need a longer belt.... I think?
Old Aug 30, 2007 | 11:49 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: underdrive pulleys and smog removal belt length
Has anybody done this modification? If so what belt length did you use?
I don't have smog, but am installing a crankshaft underdrive pulley and would like to know what belt lenght to use.....I'm thinking 95.8" but before I start buying belts and testing them a good reference starting point would be great
Thanks!
Old Aug 30, 2007 | 02:14 PM
Damon's Avatar
Just removing the smog pump from the belt routing (stock pulleys) requires a 96.8" belt. It's in the tech articles section of this board.
Old Aug 30, 2007 | 02:25 PM
Car: 1971 Camaro
I found that, I actually had to install a underdrive crankshaft pulley (5.75") in place of the stocker (7.75") because the stock pulley was hitting the crossmember on my vette.
I wonder if there is a magic formula for figuring what length I now need starting with the 96.8" belt. It would make it so much easier than trying to buy, test-fit and swap for another if it doesn't work.
The crazy thing is that the stock belt using smog is supposed to be 94.56" long according to Autozone and Advanced...........shouldn't be longer
Thanks again
Old Aug 31, 2007 | 08:06 PM
Damon's Avatar
It's longer becuase you also have to change the routing. And the required routing takes more belt.
I usually go to the store, take my best guess and carry it out into the parking lot for a test fit. As long as the belt has never been RUN, you can return it. Installing for a test fit isn't running it. Get it?
italiano67
Dec 11, 2016 09:21 AM
Navy8125
Aug 22, 2015 07:13 PM
BOOT77
Aug 10, 2015 12:20 PM
3rdgenparts
Aug 8, 2015 07:09 PM
