How to check if ECM is damaged...
Old Sep 30, 2004 | 03:09 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I was reading my Check Engine Trouble Codes and I forgot to remove the wire from the ALDL before I started the car. I remember Vader posting that you can damage the PROM or ECM if you do this. I dont think either one is damaged, but is there a way to check?
Kevin
Old Sep 30, 2004 | 03:30 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If it still works fine (engine running same as before) then I doubt you fried it.
Old Sep 30, 2004 | 04:40 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: How to check if ECM is damaged...
Originally posted by gearhead0384 I was reading my Check Engine Trouble Codes and I forgot to remove the wire from the ALDL before I started the car. I remember Vader posting that you can damage the PROM or ECM if you do this. I dont think either one is damaged, but is there a way to check?
Sure, what I normally do is, I remove the ECM from under the dash.... and then I give it a really good shaking to see if anything sounds loose. j/k
Seriously though, I agree with Adam.
Old Oct 1, 2004 | 09:10 AM
Engine: L98 350 TPI
Yeah the car runs fine.
Thank you very much everyone.
Kevin
Old Oct 2, 2004 | 10:23 AM
Vader's Avatar
These responses are correct.
It is possible to cause damage, but that doesn't always mean damage will occur. Just don't make a habit of starting the engine with the ALDL diagnostic request grounded like that. If the engine is running normally, you likely did no damage.
specialized
Jun 18, 2022 09:26 AM
AussiePr0nCar
Mar 6, 2020 04:04 PM
mddaniel
Sep 8, 2015 05:16 PM
djmarch
Aug 19, 2015 12:07 PM
