New Project. Need opinions.
Old May 16, 2001 | 02:21 PM
dallasiroc's Avatar
350 .30 over
steel crank
stock hardened rods.(X or Pink)
TRW Forged pistons 8.96:1
72cc World Prod Sportsman II Alum. heads
Edelbrock RPM Air-Gap
Comp Cams 1.6 Roller Rockers
Holley Street Avenger 770cfm
Comp Cam 294 Lift: .525''/.525'
Need opinion on this setup.
Also should I just go ahead and spend the extra $500.00 and get some H-Beams...
Old May 16, 2001 | 05:26 PM
Bort62's Avatar
Ive heard alot of bad things about the street avenger, Rather Not bad things, but un impressed things...
Other than that, sounds like a Good deal, Just be sure to ARP the rod bolts.
matching Valvesprings, ect...
I don't have alot of experiance here, but Those heads may not flow enough For what your looking For, My neighbor has the cast Iron versions, and had to Do extensive porting to get them to flow up to what he wanted, with a smaller Cam.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 16, 2001 | 06:04 PM
poncho9789's Avatar
you might need to pick a different piston with higher compression ratio. unless you are planing on runing nitrous or a forced induction system.
just my thoughts.
Old May 16, 2001 | 08:53 PM
sleeper's Avatar
I have to agree with poncho... you're building for horsepower and forgetting that torque is what gets you moving from a stop.
Your compression ratio will kill you because that big cam is going to bleed off alot of pressure (unless you are planning on using a turbo or supercharger)
David Frans
Oct 31, 2015 08:12 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
HikoriYami
Sep 21, 2015 07:11 PM
WhteRbt
Sep 21, 2015 09:48 AM
