Two questions. One on rear axle and one on electric solenoids.
Old May 16, 2001 | 11:28 PM
steve8586iroc's Avatar
First question is are the V6 diff the same as on V8 cars or are they weaker due to less hp so no need to have them as srong as a V8 car? Would it be ok to put a posi carrier
in a V6 rearend on a V8 equiped camaro?
Second question is are the any electricly operated solenoid valves on the vacuum lines? Is the egr solenoid this type? If so what voltage do it operate with?
Steve
Old May 17, 2001 | 01:09 AM
Jester's Avatar
Yeah the rear is the same..and I did exactly that. I pulled a posi carrier out of a 4th gen and put in an 84 4cyl rear. Just be sure you use the right spline axles for whatever carrier you do use.
another option is to put a Permatrax locker right in the open carrier.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
69 Six Pack
Oct 5, 2015 07:51 PM
E Rod
Aug 28, 2015 05:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
