Accel Injector Question
Old Oct 2, 2004 | 04:37 PM
GroundPoundinZ's Avatar
Just wondering how much HP 26# injectors will support. I realize you can increase the FP and get a little more out of the injector. I did a little research and found that at 60 PSI FP, the injectors are basically flowing 30 PPH. Is this sufficient for a 500 HP SB? It's a solid roller that will be seeing near 7K RPM, and I'm concerned about leaning out and/or burning up the injectors if they're near 100% duty.
I'm not opposed to getting larger injectors if I need to. If the 26# are too small, I'd like suggestions on the size I should use.
TIA
MustangBeater20
Oct 29, 2022 09:20 PM
tazs2000
Jul 15, 2017 08:44 AM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
