97 7.4L, Will it accept a carbed intake?
Old Oct 3, 2004 | 11:13 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
My current 97 vortec 7.4L swap has ran into some interesting wiring issues so I'm probably going to shelve the MPI part for the time being.
From looking at the heads with the manifold off it appears to have the same bolt pattern as any other BBC. I had a few extra BBC intake manifolds but scrap prices were just too good to pass up. Does anyone know if a carbed intake will fit? I cant seem to find any info on this anywhere and the only difference I can think of would be the EGR passage is not present in the vortec heads.
Old Oct 3, 2004 | 11:27 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
I believe on these newer motors (i.e. LT1, LS1, etc.) That they have released Carb intake manifolds recently. Well, I know the LS1 and newer Big Block truck motors had one released. check Edelbrock, Summit, Jegs, etc. I truly doubt an older style BBC-style manifold will work, bolt pattern designs and port designs. I could be wrong, but thats just my insight.
Old Oct 3, 2004 | 05:38 PM
ljnowell's Avatar
Im pretty sure the old stye one wont work either, but you can get a manifold for it.
Old Oct 9, 2004 | 03:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well I was able to round up a spare tall deck intake and guess what?
It fits!:lala:
The only apperent difference from the older gen BBCs tall deck besides the normal vortec goodies, the heads have non adjustable rocker arms which require a head gasket with a set compressed height and the heads if they needed surfaced can not exceed ten thousandths or thier trash.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
