Leaky Vlave Covers
Old Oct 3, 2004 | 06:26 PM
MisfitZ28NYC's Avatar
Car: 85 Z 28
Engine: 74 350
Transmission: 5 spd
Leaky Vlave Covers
The back side of my drivers side valve cover is leaking oil. They are the LG4 vlave covers and I think they were from an 85 305. I have a 74 350 in there now with the LG4 valve covers. The first time I put them in I used a calk gasket without any sealer and it leaked, today I put in another calk gasket with permatex sealer and it still leaked. Does anyone have any ideas on this. I was thinking maybe the valve covers warped or does a 70s engine use different valve covers, but I dont think so. I also have those 3 inch long metal bars that the valve cover bolts go through that distribute the torque of the bolt more evenly. Any help would be appreciated because this oil leak is driving me nuts and my car has been kicked out of our driveway becuase of its leaks.
Thanks,
Matt
Old Oct 3, 2004 | 06:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The valve covers are the same as anything from the '70s.
Try this... take them off and see if the flange is flat. I betcha its not. Around the bolt holes, I bet its kinda bent in because they were over tightened.
Easy to fix though. Just put them on a hard block or somthing and pound them back flat. Problem solved.
Old Oct 3, 2004 | 10:25 PM
onebinky's Avatar
Also check to make sure the machined surface on the heads are flat, and minus any deep scratches or gouges. Like air adam said though, it's probably gonna be a warped or dented valve cover flange.
Old Oct 4, 2004 | 02:42 AM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
I cleaned up the underside of my valve covers so they were spottless then flattened em out,then cleaned the head where the valve cover sits and then just used silicone around the valve cover with no gasket.set em in place with the bolts loosely in and let the silicone set.Never leaked again
Old Oct 4, 2004 | 06:52 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Try using the neoprene gaskets. They seal much better than the cork. (also do not push out of place while being tightened as bad......) and best of all..... Reusable. (to an extent)
Old Oct 4, 2004 | 07:17 AM
Car: 85 Z 28
Engine: 74 350
Transmission: 5 spd
Thanks for the info guys. I'll go out there soon to see if my valve covers are warped. Do you guys recomend a brand of valve cover gaskets to buy becuase I just bought the generic ones from straus.
Matt
Old Oct 4, 2004 | 10:55 AM
ljnowell's Avatar
My personal favorite are the cheap cork ones, never had one leak myself. If you are looking for a "better" one, try the fel-pro rubber gaskets, they dont use sealant.
Old Oct 4, 2004 | 11:11 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I just switched to Mr Gasket Ultra-Seal gaskets because the regular cork ones I put on when I swapped my heads were leaking on the drivers side. So far I have had the Ultra Seals on for about 3 months with no problems at all.
Old Oct 4, 2004 | 11:21 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
ive always used the cork gaskets also and never had a leak
i would suspect as stated before they have been over tightened at one time or another and the covers need some straightening
and remember do not tighten these down too tight they only need like 3 or 4 ft.lbs of torque to tighten them up
here check this out ...
http://www.boxwrench.net/specs/chevy_sb.htm
Old Oct 4, 2004 | 11:42 AM
ljnowell's Avatar
99.999999% of all cork gasket leaks come from 2 things. Insufficient cleaning of the mounting surfaces or overtightening. As a matter of fact, the passenger side valve cover has been taken off my car three times, and i have the same cork gasket on. If you put sealer on the valve cover, and stick the gasket to it and let it tack up. Then clean the head real well. No sealer on the head at all. This way you can pull the cover and still reuse the gasket, most of the time.
Old Oct 4, 2004 | 02:26 PM
Air_Adam's Avatar
I just get the rubber gaskets, and use black silicone to 'glue' them to the bottom of the valve cover. Once they are cured, put them on the heads, tighten them up and they never leak. That way, they can be removed and reused a couple of times too, if needed.
Course getting cast aluminum valve covers usually fixes most sealing problems too
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
Dragonsys
Sep 25, 2015 03:51 PM
