Where the He11 is the PCM or PDC or whatever its called
Old May 17, 2001 | 11:00 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My insterment lights will not go on and the fuse is good. I know I blew somehting and the dash is apart and I dont know where to look next for it. Thanks
Old May 17, 2001 | 02:00 PM
Guest
Guest
Posts: n/a
Dimmer module, or whatever, is that what you are talking about?
I wasnt even sure Camaros had them (that is what you have right?)
Look up above the 'Convenience center' under the dash driver side, right of the wheel, its right where the ALDL is. Above that, mounted to a metal bracket that I have no clue where its all attached to, in a next to impossible to get to spot is the dimmer thing.
Definitions:
Convenience Center - GM's excuse for an easy spot to get to.
ALDL - The spot you spend lots of time in reading stupid information from your computer.
Dimmer thing - A 5 dollar part thats a PITA to access.
Old May 18, 2001 | 12:50 AM
Vader's Avatar
Max is on it.
Maybe these would help:
The "Convenience Center":
The dimmer module:
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bschmale66853
Sep 30, 2015 08:11 PM
