What would be a good cam and which carb do you like?
Old May 18, 2001 | 01:14 AM
Golden80's Avatar
I have a stock LG4 305 in my car and was wondering what suggestions you all had on a camshaft. I'd like a bit more SOTP oomph but don't want anything that would require numerous other mods to work right. Would a Comp XE262 be a good choice?
And also...I know this has been debated but just wanted fresh opinions. I still have my computer controlled QJet on the 305. I also have a Holley 600cfm double pumper, brand new, in the box. The Holley was going to go on a different car but I decided otherwise on that car because I'd like to keep it stock. Will the DP not be happy with the high altitude? I do know that I'd have to buy an adapter to get it on the intake and I'd also have to change out the distributor.
And this is my current setup:
Stock LG4
Gutted catalytic converter
Monza tip mufflers
Thanks for the help/advice,
Matt
Old May 18, 2001 | 06:59 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
See my SIG. I have the XE262 and the original computer controlled Qjet. Nearly 101 MPH in the quarter cant be wrong!
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New! 275-40-ZR17 tires on ROH ZS 17 x 9.5's
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
