Play in steering
Old Oct 5, 2004 | 08:26 PM
patRIOTik's Avatar
Car: 1986 Chevy Camaro Z28
Engine: 4BBL 350
Play in steering
Hey, i have an 86 Z28 with power steering and im getting about 5* of play to the left and right from center. Is this a bad steering box? Power steering pump?
Let me know any details you may need posted, ill be more then happy to help you help me
Thanks.
Old Oct 5, 2004 | 08:40 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Any number of things can give you play in the steering. From the rag joint to the outer tie-rod ends. You need to look, and see where it is coming from. Have spare set of hands move the steering wheel back and forth (engine off, and only to the limits of the play), and watch and see which parts are sloppy.
Or, jack up the front of the car, steering locked, and grab ahold of one of your wheels at the 3 and 9 O'clock positions, and see how much you can move it. Look to see what parts are responsible, and replace 'em.
The steering box can be tightened up some, but, be careful, as it is possible to over-tighten it, and have truly bizarre on-center behavior. (Voice Of Experience. Your car will NOT go straight down the road.)
Old Oct 5, 2004 | 08:43 PM
patRIOTik's Avatar
Engine: 4BBL 350
Hey, thanks alot. I'll take a look at those.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
