Anyone gone faster with stock PROM rather than a Hypertech??
Old May 17, 2001 | 04:20 PM
Yarnboy's Avatar
I am thinking for my next mod I should swap back in the stock PROM. Hypertechs seem to be expensive run rich sticks. I can do without on of those..Has anyone noticed any gains by putting their old PROM back int?
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
Old May 18, 2001 | 06:14 PM
Yarnboy's Avatar
Should I move this to TPI? The PROM board is smart enough to never have used Hypertech..So I don't think that's a good idea..
Old May 19, 2001 | 11:55 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Yarnboy: actually, post this question on the prom board. You will find a more definite answer with proof to back it up. I am also for sure though that they will tell you to ditch it.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
Keith5
Aug 27, 2015 04:37 PM
NBrehm
Aug 25, 2015 11:49 PM
