Oil Cooler Leak
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Oil Cooler Leak
I got a problem with my oil cooler, everytime i turn my car on it seems to leak from where the oil filter and the oil cooler meet, and i know it aint the gasket from the oil filter cause i changed the oil filter and it does the same thing, and i tried getting the gasket for the oil cooler neither Gm or autozone, or carquest. so i dont know what to do, is there a way to fix the prob? and is this the right part # 88893990 - oil cooler gaskets?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Are you saying iits leaking oil or coolant.If its oil There is an O-ring seal on the cooler where it mounts to the block.the 0-ring is similar to the filter 0-ring(it might even be the same size).If its coolant then it could also be the two 0-rings on the coolant tubes(if theyre aluminum).Where they bolt to the oil cooler.Dont know about your part# though.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
