Higher FP or bigger injectors?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi...
What are the pro/cons of getting bigger injectors vs. raising the FP?
For my app:
I need bigger injectors I have found 2 that looks good
- 65 lbs p/h
- 57 lbs p/h
What would be best
- use the 65 at 43 psi or
- use the 57 with rasied FP to gain better spray pattern, maybe?
/N.
For my app:
- 65 lbs p/h
- 57 lbs p/h
What would be best
/N.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Ok, but if I go #57 and raise the FP so that they will be #65, how about the spray pattern?
#65 at 43 psi vs #65 at 55 psi?
/N.
/N.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Get the largest injectors you can afford.
Up the fuel pressure. I'm running around 50psi at idle.
Then set the bpw really low.
Don't listen to folks running stock setups and expect any sort of advice on injector selection. Leave it up to the diy_prom guys who have experimented with multiple setups.
-- Joe
-- Joe
Dont worry about spray patterns.
