Help!! Fuel pressure drops 6psi every 5mins!!
Old May 20, 2001 | 07:57 PM
Like a ROC 89's Avatar
I have an '89 Iroc L98. It has 60k miles on it. I went to check the fuel pressure and primed the rails by turning the key on and off with the fuel pressure guage connected. It initially read 46psi but after about a minute it dropped 2psi and 5 minutes it read 40psi. It will probably be at zero in about 20minutes. I have checked the AFPR and it has no leaks, no leaks on new fuel guage eighter. I have heard that the TPI fuel rails should hold pressure for like 10hours. What could be wrong?
Thanks!!
Old May 20, 2001 | 08:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My pressure is gone in 10 minutes. I wouldnt worry.
89 FORMULA 350 Edelbrock Cat-Back ,March Pulleys,Super Coil,MSD 6AL ,Edelbrock TES's, AFPR ,Shiftkit, Edelbrock Base ,AS&M Runners, Edelbrock Waterpump, MSD 22# Injectors, Hoping for 13.5
Old May 21, 2001 | 07:56 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Unless you're having hot start problems with extended cranking and a plume of black smoke and/or gas smell, don't worry about it.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
