Fuel Lines?
Old May 19, 2001 | 02:51 PM
88 IROC BOB's Avatar
Fuel Lines?
I can't remember which is the feed and which is the return (larger and smaller ones)?
I've pinched them both off to check for leaking injectors, I still lose pressure.
I think the bigger one is the feed but please correct me if I'm wrong.
Bob
Old May 19, 2001 | 04:58 PM
SCRA rules!'s Avatar
'93 2wd truck
408 sb, vortecs, 454 TBI, Comp Cam, dual exhaust
Old May 20, 2001 | 07:55 PM
Thank you!
Old May 21, 2001 | 07:59 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
If you have pressure and watched the guage as you pinched both off and the pressure still dropped, either the fuel is leaking into the vacuum hose of the pressure regulator or the injectors are leaking (more likely)
Old May 21, 2001 | 08:17 PM
There is no fuel in the vacuum line so it has to be injectors. The thing that gets me is I had these cleaned and flowmatched last year and it has still experienced the same problem.
I guess I'll get some new ones.
Bob
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
