LT1 Heads
Old Oct 14, 2004 | 12:24 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
LT1 Heads
Hi!
Does any of you have any experience of the stock LT1 heads,are they any good.I have a deal on a 355 engine whith LT1 heads and a compcam,dont now the specs for that yet,please respond.Thanks.
Old Oct 14, 2004 | 01:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Are these the modern LT1 heads, or the old-style LT1 heads?
I ask, because a Gen 1 small block won't work with modern LT1 heads unless they have been modifed quite a bit.
Old Oct 14, 2004 | 02:02 PM
fnoblitt's Avatar
lt1 heads ?
i'm coureious about the lt1 heads, i have a pair of alu. lt1 heads from a 95 trans am.i would like to put on my mid eightys block. how much work is involved to make them work ?thanks
Old Oct 14, 2004 | 02:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
look up a guy named tpiroc (i think that's the name, I apologize if it isn't). He has a thread about how to modify a 2nd gen SBC LT1 head to work with the Gen. I sbc block.
Old Oct 14, 2004 | 02:17 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I'm in the process of doing this but instead of going on my 305, I'm just going to build the 350 with these heads. Once I get the heads all done and rebuilt though, I'll make some sort of a write-up. Its not a lot of money, but it is a lot of work I suppose... Need to use LT1 intake for best results and easiest install..
Old Oct 14, 2004 | 02:31 PM
fnoblitt's Avatar
i'd like to know what kind of work do you have to do to the heads to make them work on a gen 1 block ?
Old Oct 14, 2004 | 07:50 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
On the bottom of each head there are 2 coolant passage holes that need to be plugged and welded up. From my understanding there is no coolant crossover passage from the heads through the intake on the LT1, but there is a hole drilled out on the face of the head, where the accessory bolt holes are. You use these holes to run coolant lines to a remote thermostat housing.
As already suggested, do a search for a post by tpi_roc on LT1 heads. There are pictures of what is needed, as well as other good info.
I've got a set of LT1 heads at home, and I'm waiting on an intake/injectors/fuel rail so I can swap them on my car over the winter.
Old Oct 16, 2004 | 05:19 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
There was a missunderstanding the engine he had was the old style from a -74 corvette,so I am still looking to find that 355 or 383 to do the swap from my 305 this winter.
Thanks anyway.
Old Oct 16, 2004 | 07:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You don't want a 74 Corvette engine; at least, not a USA one. Maybe export ones were better. But here, those were the absolute worst years for those..... 73 to 82. They were the same smogger pig that you would have got in a 2-barrel Impala: same low-flow low-compression smogger heads, same low compression pistons, same lame cam profile (the "929" cam). Wrapping it in fiberglass instead of family sedan sheet metal didn't improve the engine one HP or ft-lb.
Keep looking. That's not a good whole-motor core to buy as the foundation for a build-up; especially not if you have to pay some inflated "Vette" price for it.
Old Oct 16, 2004 | 10:14 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
OK!
But I dont think that many parts were stock on that engine,it have been modificate to deliver 350hp but anyway it is nothing for me.
By the way,does any of you have comments of what engine I will invest my money on: a350 crate or 383 stroker or a 350 TPI oveall I am looking for a nice low end torqe and a top end power at 300-330hp at the flyweel.
Thanks!!For any replay.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
