new windage tray in old block
Old Oct 14, 2004 | 06:50 PM
classicgm's Avatar
Car: 92 RS 25th Anniversary Edition
Engine: treefiddy
hey, I'm about to put my 383 together and was orderin the last parts ands the guy I talked with told me that I could not install a windage tray without having the mains line bored... he said that the forces of the new studs would cause the block to be pulled our of shape and anyway it;s a no go... I never heard of this before and I cant see that installing studs (instead of factory bolts) would cause that much difference. am i totally wrong or what?
Old Oct 15, 2004 | 10:22 PM
classicgm's Avatar
Engine: treefiddy
yeah, ok. the problem is that the studs are torqued differently than a bolt and yes, it can distort the block enough to cause problems.. :lala:
Old Oct 16, 2004 | 11:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well, I added a windage try to the 73 model 400 block that I put in my 83 car back in about 88 or so; seemed to run fine for around 140k miles or thereabouts.
I wouldn't worry about it.
Get the right pan to go with the tray. A typical stock pan isn't set up for one, and it won't fit very well.
Here's the pan I used. I used the Moroso Teflon-coated tray instead of the GM one though; with the GM hardware.
http://www.paceparts.com/index.asp?P...D&ProdID=25496
Incidentally, it WON'T work on all motors up to 85; only blocks with the left-hand dipstick.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
