head casting question
Old Oct 15, 2004 | 09:52 PM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
anyone know anything on a # 3973487X head, all i can find is that it was a 68-73 350 lt-1 head, but the X is supoose to mean 10cc port port volume, suppose to be 330-350 hp head, was cast on Oct 19th of 1971,i also have the 1.94/1.5 valves, one site claimed that the 487x casting had 2.02/1.6 but thats false. but was a lt-1 vette head.
Old Oct 16, 2004 | 07:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That casting was actually used in about 71 and 72, the last of the years of the LT1, after it got smogged like everything else. I don't know about it being around before then. They were decent heads as far as flow; not the best, but pretty good.
On the other hand, their chambers are so large, it's impossible to get decent compression with them, unless you're running a 400 or larger motor, with flat tops; or you use domed pistons which is a highly inferior way of raising the CR.
They sell easily to people with the old LT1s though, for good bucks; that's what I'd do if I had one (!), go advertise on one of the sites that caters to older Camaros and Vettes, or in Hemmings, or the like.
Old Oct 16, 2004 | 09:19 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the heads have the extra steam holes in the deck they are off a 400ci motor. Chamber size could be as big as 80cc. Not bad on a flat top 383 or 406 motor with porting and larger valves etc. If you're building a 350 then starting with a 305 HO head (small chamber) is better.
Great for a blown or turbo 350 project thou.
Old Oct 16, 2004 | 10:30 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
3973487X...71-72...350..........75cc chamber
Old Oct 16, 2004 | 11:00 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
hey I need those heads. my comp. is too high and that's just what I need
Old Oct 16, 2004 | 11:14 PM
Car: 2000 firehawk
Engine: ls1
site: http://www.thedirtforum.com/castings.htm
3973487 68-79 1.94/1.50
& 2.02/1.6 165-330 76 CC Chambers
X casting has 10 more intake
cc volume.
and another site: http://www.chevytalk.com/tech/engine/SBC_Heads.html
LARGE CHAMBER PRODUCTION "ON CAR" HEADS
"487" – 3973487, OR 3973487X. The regular casting was found on the 1971-1972 350 LT-1 engines, had 1.94/1.50" valves, 76CC combustion chambers, DO have accessory holes, intake port volume should be 161CC's, exhaust port volume should be 65CC's. The 487X had 2.02/1.60" valves.
btw just finished up the d/s head, all nice n shined up and fresh valves, springs, n seals, just the other argh
Old Oct 16, 2004 | 11:31 PM
THEGENERAL's Avatar
this was from www.mortec.com
and this is from www.nastyz28.com
1968-72 3973487 350 1.94 1.5
1968-73 3973487 350 2.02 1.6
MustangBeater20
Oct 29, 2022 09:20 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
