vapor cainster lines???
Old Oct 17, 2004 | 11:33 AM
bigbird88's Avatar
Hey,
Here is what I have a a 87 Ta with a 305 tpi. I did a search and my cainster matches a diagram I found here for a 85-86 All but one hose has a home. The top of the cainster has a square block with two hoses one goes to the tb (side) the other goes to the round control valve on the other side of the cainster. That control valve has one hose going to the control valve that goes to the tank. The fitting in the center goes tothe same control valve then out to the fuel tank. The hose without a home tees off the hose that goes from the control valve on the cainster to the valve that goes to the tank. In the diagram it look like it goes to the underside of the plunem to the tb but here is already a hose there should this tee into that hose??
Thanks!!
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
