What's This
Old Oct 17, 2004 | 03:02 PM
wc00ac's Avatar
Car: 92 Camaro
Engine: 305 TBI
What's This
Didn't know exactly where to put this so here goes. I found this when I was pulling the carpet from the car to be cleaned. What is it and whats it for?
It says Gm code key.
Old Oct 17, 2004 | 03:05 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
it probably has the vats resistor code on it in case u ever loose the key
Old Oct 17, 2004 | 03:24 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
It looks like the key that you stick in the ALDL port to check for trouble codes. Instead of a paperclip you use that key to ground pins a and b.
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Did you ever read how you can pull codes with a paperclip? Well that key serves the same purpose. My friend that works at autozone gave me one
Old Oct 17, 2004 | 05:17 PM
ljnowell's Avatar
Yep, i got about 5 of those here right now.
Old Oct 17, 2004 | 07:32 PM
wc00ac's Avatar
Car: 92 Camaro
Engine: 305 TBI
Now where does it go???? Anyone have a pic? Thanks for all the help!
Old Oct 17, 2004 | 08:35 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Look for Vaders post:
https://www.thirdgen.org/techbb2/sho...highlight=aldl
