Wanting to upgrade my ignition
Old Oct 14, 2004 | 06:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok so i want to upgrade to either msd or accel for my ignition, the wires, cap/roto coil and box.
i'm leaned more towards msd products for their reputation.
but when i see all their stuff, i dont know which to choose, so my question is, which coils work best on our cars and what exactly does an ignition box do? i hear the 6AL is good.
Old Oct 17, 2004 | 01:36 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ttt
Old Oct 17, 2004 | 01:42 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The stock ignition is fine for what you have. I wouldnt bother messing with it.
Old Oct 17, 2004 | 07:58 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
To add to the above comment, the stock ignition is great up to around 400HP. Now, if you are having trouble with some items just replace then with AC Delco. Parts store crap is just that, crap. Even most aftermarket isn't as good as AC Delco electronics.
Old Oct 17, 2004 | 09:16 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i would like an ignition box for the timing curve i can put in, rev limiter and of coarse multispark cant hurt fuel milage.
so help me out here!
Old Oct 17, 2004 | 06:54 PM
Engine: 4.0L
You can do all that with the stock ignition system. All you need is a programmer so you can start burning your own custom chips (proms).
Old Oct 17, 2004 | 08:10 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Which is going to be easier especially on a near stock car, learning the art of chip burning or buying an aftermarket ignition setup?
Old Oct 17, 2004 | 08:37 PM
Engine: 4.0L
Learn chip burning for sure. It will always be with you and you can experiment over and over again wit different variables. If you can't swing the price of a programmer ask a buddy to go in with you and split the cost.
If you buy an aftermarket ignition that's it, your done. I'll bet a paycheck you get more power from chip burning then with an aftermarket ignition system on a stock engine.
Old Oct 17, 2004 | 09:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I agree 100%. An aftermarket ign is good only for the enhancement and whatnot of spark energy, for the most part. Chip tuning opens the doors to a whole new world of performance, which in the end, will be a far greater asset then a ign. box.
Jake_92RS
Jan 28, 2020 10:37 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
