My LO3 failed emissons
Old Oct 17, 2004 | 09:45 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Maybe you guys can shed some light on this:I failed 1 part of the test
HC ppm
limit: 65
my reading: 121
everyything else passed with flying colors.I changed the oil ,air filter and pcv before the test.
Old Oct 17, 2004 | 10:40 PM
NascarFool's Avatar
Car: 1989 Iroc-Z
My sons Rustang kept failing on high HC and CO. We found out that someone had gutted the converters. New converters got installed and it passed. Check the O2 sensors, smog pump and smog pump related parts.
Old Oct 18, 2004 | 12:52 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Try using a can of emmisions cleaner like 104's and change your O2 sensor. Also If your oil level is high it can increase your HC's.
Old Oct 18, 2004 | 10:55 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since you didn't list O2 sensor as one of the things you replaced, I'll 2nd that recommendation. But, you didn't really do a "tune-up", so plugs, wires, cap & rotor would also be a good idea.
A misfiring cylinder or leaking injector can also increase HC's.
Old Oct 18, 2004 | 11:29 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Check your timing as well. A bump in timing can have a big effect on HC's.
Old Oct 18, 2004 | 11:45 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
HC is misfire. Double check timing & do plugs, wires, cap, rotor, and you should be good.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
