ATTN GMTech: Carb to TPI conversion question
Old May 22, 2001 | 10:53 PM
CamaroX84's Avatar
I am swapping in a 5.7 speed density motor into my 84 LG4 Camaro. What do I need to modify on the dash harness to make it work? I have the Painless wiring harness for speed density TPI. I also have the 90-92 ECM. Thanks in advance.
Old May 23, 2001 | 05:57 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You can use the ALDL that Painless gives you, just remove the light that comes with it, and route it behind the radio. Most other wires like the P/N switch, Brake switch, etc... can be spliced into the harness at C207 under the passanger side dash. This is the connector that meets up w/ the ECM wires before going out the PassThrough behind the passanger fender.
I got to warn you, if you run the wires through the factory passthrough like I did, the harness is too short. You will either have to drill a hole in the firewall, or lengthen the harness.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
MustangBeater20
Oct 29, 2022 09:20 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
