IS THERE A WAY TO JUMP THE A.L.D.L.?
Old May 23, 2001 | 10:20 AM
untchbl88's Avatar
I HAVE BEEN GETTING AN ENGINE CODE THE PAST COUPLE OF DAYS, AND I WAS WONDERING IF THERE IS A WAY TO JUMP/BRIDGE THE ALDL TO FLASH THE CODE TO ME. IF ANYONE HAS ANY ANSWERS I WOULD APPRECIATE IT GREATLY
Old May 23, 2001 | 10:33 AM
irocbsa's Avatar
Turn the igniton on (do not start the engine) and insert a paper clip into the two terminals on the top right of the ALDL connector. It should flash a code twelve (no distributor pulse reference) three times then the trouble code 3 times followed by the code 12 3 times. It will keep doing this until you take out paper clip. The trouble codes are listed in the technical articles under Fbody FAQ.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old May 23, 2001 | 10:46 AM
untchbl88's Avatar
thanks irocbsa, i will try that when i get off of work. again thanks for the tip it is going to save alot of time and money
Old May 23, 2001 | 11:18 PM
Guest
Guest
Posts: n/a
Just in case...
'12' is one flash, a pause, and 2 flashes of the check engine light. It does that 3 times before it will display the codes, and they are read the same way.
db057
Jan 10, 2020 08:55 PM
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
86White_T/A305
Mar 6, 2016 01:48 PM
RedLeader289
Sep 23, 2015 06:50 AM
