WIRES, How often do you replace them?
Old May 24, 2001 | 07:53 AM
Steve89GTA's Avatar
How often do you replace your ignition wires?
Steve
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Old May 24, 2001 | 08:04 AM
ede's Avatar
ede
i usually upgrade to preformance wire set and then only replace if i break or burn one. on a street car/daily driver once every 2-3 years.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Glowsock
Jul 24, 2025 03:15 PM
specialized
Jun 18, 2022 09:26 AM
marcusaw
Aug 10, 2015 08:13 AM
