Home porting...what about polishing
Old Oct 25, 2004 | 03:02 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Okay, so I'm porting a set of LT1 aluminum heads here using a round file that I ground in half and an electric drill. Its actually working surprisingly well. Time consuming though!
Anyways, I was curious if its worth it to polish the ports and bowls when I'm done, and how to do it?
Old Oct 25, 2004 | 03:44 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: Home porting...what about polishing
No, the only part of the head that you want to polish is the exhaust port. A rougher finish, around 80 grit or so, is more suitable for the intake port and bowl so that the incoming air/fuel charge gets thoroughly mixed up before entering the combustion chamber.
Old Oct 25, 2004 | 03:52 PM
Car: 1997 Corvette
Ah okay, so what type of bit should I get to polish the exhaust port? Would I be able to get the part from somewhere local?
Old Oct 25, 2004 | 04:06 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Dude, the best thing you can get is a set of sanding rolls from Standard Abrasives. I used that to clean up my intake/bowls and exhaust ports. They have all kinds of grits in there. Like said the only thing that needs to be "polished" is the exhaust port and combustion chamber...
Have you ever done this before?? Know what you are doing? Read up on this at all? If not you stand to hurt more than help if you try to do too much...
Old Oct 25, 2004 | 04:15 PM
Guido's Avatar
Car: 2000 Trans Am
Try using an air nibbler
Old Oct 25, 2004 | 04:36 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
pollinshing the combustionchamber in my opion is worth a bunch, but I do not know what to do as I have heard that if you polish the chamber you better know what you are doing or the flow can be messed up. Maybe what i heard is BS
I don't know for sure
later
rk
Old Oct 25, 2004 | 05:00 PM
Guest
Guest
Posts: n/a
Follow that up with a coat of Zaino?
Old Oct 25, 2004 | 05:24 PM
Engine: 305-4v
Follow the link at the end of my sig, it has lots of pictures and will answer all your questions.
Old Oct 26, 2004 | 12:07 AM
Car: 1997 Corvette
Cool thanks, I had skimmed through taht thread many times in the past and I've read many other articles on DIY porting. I'd say I'm doing very similar to what you did except the valve guides protrude quite far into the bowls on these LT1 heads. In either case, I'm working to fix that and smooth everything out...that's my goal, just to smooth everything out. I'm not trying to change the shape of anything except the material around the valve guides.
Just didn't know how to pollish
Old Oct 26, 2004 | 02:42 AM
Engine: 305-4v
Some places don't polish the exhaust, they just leave it with the carbide cutter's finish. Polishing does look nice but if you get a good surface finish with the cutter you might find that it will be good enough. Basically, you don't want to leave any indentations or gouges but rather want a fairly smooth and consistent finish throughout the port, bowl and chamber.
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
