Tired, just tired.
Old May 23, 2001 | 11:49 AM
Steve89GTA's Avatar
Tired, just tired.
New-TPS,Wires,plugs,CTS,Fuelpump/filter,entire distributor assembly, clean IAC, coil, clean TB,
what is causing my off idle bog? My Idle is perfect, car bogs just above it though unti around 2000rpm, don't know why,
Any suggestions? zzzz
Car passed emissions...is my cat clogged (it's only a year old). No Air connected.
I'm lost...
Fuel injector clean up? expensive? New IAC..getting tired...need new car...zzzz
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Old May 23, 2001 | 09:31 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
What's the base timing set at? Should be 6* BTDC w/EST bypass line disconnected.
May want to unplug the MAF wire harness as see if it improves any.
Shouldn't be a cat issue, you'd still be sluggish as the RPMs increased.
Might be time to plug into it with a scan tool...any codes set?
Old May 24, 2001 | 07:52 AM
Steve89GTA's Avatar
MAF is a bosch unit only 18,000 miles old. No Codes set. Will swaping the MAF relays help? It feels like a lean condition just off idle or something like that.
Thanks for your help
Old May 24, 2001 | 08:06 AM
ede's Avatar
ede
might want to consider cleaning and flow matching the injectors. i think cruzin preformace cost 80 dollars, vader speaks highly of them.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 24, 2001 | 08:24 AM
Steve89GTA's Avatar
Ya, I was thinking of the injectors being the problem.
Steve
Old May 25, 2001 | 09:39 AM
mtx28's Avatar
timing. my car was the same way, i'd say there's a 90% chance its timing, if the other stuff you've checked is working
  • 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
  • 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
Old May 25, 2001 | 10:05 AM
Steve89GTA's Avatar
When I had the fuel pump/strainer/filter replaced, they checked the timing and it's fine. I have a feeling it's that ****en EGR valve or solenoid...the solenoid being the part that no one on this board seams to know anything about..lol.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
