Help!!! Cam installation and valve to piston clearance
Old May 24, 2001 | 10:45 PM
NORT's Avatar
I have been having the nightmare of nightmares! It started out with just doing a simple cam change or so I thought.I had a 214/214@50 443 lift cam not much of a cam. I got a Comp 268 xetreme cam to put in and I just can't figure out what is up. I have went through the entire engine (rings ,bearings,polished crank,valve job,cam,timing chain) the whole thing , now i'am putting it back togather and don't seem to have any piston to valve clearance. It is just a 480 lift cam iam using Sliv-lite Hypereutectic pistons with 4 valve reliefs and iam using the L-31 Vortec heads. My deck height is .050. I know that there is alot of guys are running this combo with no problem. Iam sure that iam doing something wrong with my timing, I set it up with the timing marks just as the book says (or so I think) and just at top dead center or just before the intake valve hits the piston. I was doing the clay deal to check the piston to valve clearance and its a good thing or I could have had one H--L of a mess. I don't know if I have given enought info for anyone to give me any feedback on but if so please get back with me. Thanks NORT
Old May 25, 2001 | 12:23 AM
Guest
Guest
Posts: n/a
Yea, that cam shouldnt have a problem...
Is the dowel pin lined up with the hole in the cam sprocket? That or the cam was ground wayyyyyy off.
Old May 25, 2001 | 12:28 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Recheck the timing chain. With #1 cylinder at TDC the timing marks on the gears should be lined up together. The crankshaft keyway should be around the 2 o'clock position.
Are you using standard 1.5 rockers or higher 1.6 ones?
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 25, 2001 | 08:39 AM
ede's Avatar
ede
all the flat tops pistons i've ever used or checked would need a cam with over .600 lift and i do mt checking without a gasket so you can add another .040 to that. i agree i'd go back and make sure the dowel and gears are correct and degree the cam to see if it's ground wrong.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 25, 2001 | 08:43 AM
CamaroZ_85's Avatar
if you cant get it figured out, call the comp cams tech line and see what they suggest for you
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old May 25, 2001 | 11:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like the cam is out of time...
Locate the #1 piston at TDC; the crank key is eaxctly lined up with it, so it should be pointing exactly at 45°, and at that point the mark on the crank gear should be straight up... take the cam gear off, take the chain off, put the gear back on with one bolt finger-tight and turn the cam so that the mark on the gear points straight down; take the bolt out, and put the gear back on.
You should not be having clearance problems. In fact, you should have at least .350" of clearance with it properly timed. It's even possible that the valves shouldn't hit the pistons at all no matter what the cam timing is, I know that at .410" of lift, the valves miss the pistons altogether with a broken timing chain (BTDT a couple of times in my life).
ICON Motorsports
Old May 25, 2001 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Another thing to check is to make sure that's the correct cam. Look at the grind number on the front of the cam. It should be 12-242-2
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
