Depressurizing Fuel System
Old May 23, 2001 | 11:27 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
I have to re visit my intake gasket instalation because of a bad seal at the back of the motor. Last time I forgot to relieve the pressure in the fuel injection system. It got MESSY! SO the haynes manual says to pull the fuel pump fuse in the Fuse box. I can't find any fuse that is related to the fuel pump or fuel system (90 Iroc).So how do I disable the fuel pump without gettin underneath the car. Where might the fuel pump relay be on my 90 Iroc (LB9)?
1990 Iroc convertible,305 tpi,Black with black leather interior,lowered
Old May 24, 2001 | 12:17 AM
Enkil's Avatar
There's a fuse in the fusebox labeled FP/INJ or a fuse by the battery in a little black box that's supposed to be bolted to the side of you car. (Mine broke off.)
Actually, I had both, so I unhooked both of them. I unhooked them, took off the gascap to depressurize it, and then ran the car to get the fuel out of the lines.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old May 24, 2001 | 10:05 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Your car shouldn't run at all if you unplug that F fuse in the engine compartment. That fuse is also the main power to the ECM, at least it is on TPI cars.
To disable the FP you want to get to the FP/guage connector which is back by the tank, in front of it, all the way up under there. If you are under the DS in front of thw wheel by the FF you can see/get to it w/o too much trouble.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old May 24, 2001 | 02:58 PM
rondubbs's Avatar
guys, why are you doing things the hard way? no fuses need to be pulled, pumps disabled.. all you need to do is take the gas cap off and wait a few hours/over nite and the fuel pressure will be 0. if you dont want to wait over nite, go to the schraeder valve with a rag and let the pressure out.. this is the easiest way to do it, in my opinion.
Old May 24, 2001 | 03:04 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Yeah, do that... Unless you for some reason need to turn on the ignition switch. Then you'll power up that fuel pump :-)
Mint black/black 1987 T/A GTA 305 5-speed, 55K,
3.45 factory POSI,SLP cam, SLP runners, Taylor wires, hurst comp plus shifter, K&N conical rig, AFPR, coated shorty headers, no cat, no smog, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 160 stat, SFC's, lower control arm adapters, Aluminum Driveshaft, ported upper and lower, Mobile ES and 10 disc, kickers all around and q-logic kick panels...Perf 350, rear batt, lowering springs,cowl hood, & NOS coming soon!
Old May 24, 2001 | 09:40 PM
Engine: LB9
Cool, if thats all that is required then thats what I'll do. Thanx guys
Old May 26, 2001 | 12:19 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Not that I ever do it myself, but the safest and cleanest way to do it is by pulling the F/P-INJ fuse and running the engine. You can diconnect the plug to the tank, but it's a PITA to get to compared to the fuse unless you already have the car in the air.
I usually use the "let it run all over the place" method, and end up smelling like a gas pump for a few hours!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
