Drivers side dipstick oil pan in 3rd gen
Old May 25, 2001 | 07:55 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
My new crate motor is based on the older block design that has a driver side dipstick.
I noticed on the first attempt to put the
motor in, the oil pan is very close to the
major frame cross member. Was also thinking
of clearance for the Y-pipe that runs between
that cross member and the oil pan sump. Headers and ypipe are TES. Anyone have problems with either of these two? Must be lots of swaps with this combination.......
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Old May 25, 2001 | 08:00 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
My 400 has a driverside dipstick (not including me )and fit's with no problems.
Old May 25, 2001 | 08:36 AM
ede's Avatar
ede
i put a 355 in my sons camaro with a left side dip stick and no problems, even with hooker headers.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 25, 2001 | 06:49 PM
Bill86Z's Avatar
If you use aftermarket headers you should have no problem. The problem starts when you try to use the original exhaust manifolds.
Old May 25, 2001 | 08:44 PM
Damon's Avatar
Just installed a 1975 400ci small bock in a 1987 Trans Am using the original 400 oil pan (block-mounted driver's side dipstick) versus the origianl passenger-side pan-mounted dpistick.
No problems to report using aftermarket headers and y-pipe. The pan must be VERY similar to the original 350 pan than cam with the car becuase the y-pipe fits between the front of the pan and the rear of the crossmeneber like it was built for the car from the factory!
I think Bill86Z has it right. The only way you'll have a problem is if you try to reuse the factory "above the exh ports" manifolds. Then the block-mounted dipstick will have problems clearing the manifold. But with headers.... not an issue.
Old May 25, 2001 | 09:48 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Thanks guys, I think I'll do a quick fit-up
of the headers + y-pipe on the motor before I
drop it in.
Tom K.
Old May 26, 2001 | 12:41 AM
MeanYellowZ's Avatar
agree with everyone, sucks with stock manifolds, but with headers....all is clear
Currently own: 2001 Xtreme, 85 IROC, 87 S10
pics of my old 86Z:
Camaro1 Camaro2 Engine
More at: My Directory
Email: MeanYellowZ@hotmail.com Aol/IM: RCY1980
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
