Original LT-1 Heads
Old Oct 28, 2004 | 12:11 PM
bigj85z-28's Avatar
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
Original LT-1 Heads
Can original LT-1 heads that were used on 71 Camaros, with the 370HP 350 for example, be used on a TPI setup? I have found a set that are fully race ported and polished with double valve springs and erson roller rockers for about 400 bucks. And I'm pretty sure theyd be able to make some good power. Moreso, would these be compatible with a Stealthram Intake? If so, I could be lookin at gettin' one helluva good setup here.
Thanks for the help.
-Justin
Old Oct 28, 2004 | 03:11 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What is the casting number on the heads?
Old Oct 28, 2004 | 03:26 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
You may have to drill out the middle holes on the intake to make it fit but other than that they should bolt right up. But depending on the casting they may or may not have acccessory bolt holes, so find out the last three digits of the casting number and let us know.
Old Oct 28, 2004 | 05:03 PM
ljnowell's Avatar
CHECK THE CASTING NUMBER! Sorry, I didnt mean to yell, but you need to make sure to do this. A lot of times, heads are from "400hp motors" or the like, and they are junk. Kind of the same way every 305 becomes a 350 at time of car sale, and every 350 is from a 'vette. Get the casting numbers, do yourself a favor.
Old Oct 28, 2004 | 05:52 PM
Drakar's Avatar
you forgot all motors are then HO!!
Old Oct 28, 2004 | 06:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yes they can be used. The only issue might be the bolt hole angle for the intake manifold. Thats not a big deal though, a search will tell you how to fix that.
If they are real '70 LT-1 heads (only year for 370hp) they might not have hardened valve seats though, because they were designed for leaded fuel. TPI can't use leaded fuel. Hardened valve seats can be installed though.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
cRoe4
Aug 7, 2015 08:46 PM
