Gas gauge twitches
Old May 26, 2001 | 01:01 AM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
Gas gauge twitches
My gas gauge just started having siezures. At a constant speed and smooth acceleration/deceleration the gauge is fine but as soon as you jerk the car at all the gauge goes bonkers and twitches badly. Could it be the float in the tank or the gauge itself?
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.32@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake, ported heads.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box, gutted cat.
Old May 26, 2001 | 09:27 AM
Biochem's Avatar
Car: 2002 SOM z28
Get used to it, because it will only get worse. Mine does the same thing and now will sit at way above F until one day it drops to 1/2 tank and acts normally until E. It is the sender in my case because it did it with the stock gauge and now with the Autometer one too.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old May 26, 2001 | 12:53 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Did it act exactly like mine does before it started doing what it currently does? I would like to fix this problem. What is involved in dropping the tank? Does the rearend have to be removed?
1986 CAMARO Z28 ->
1987 TRANS AM ->
Old May 26, 2001 | 07:55 PM
Biochem's Avatar
Car: 2002 SOM z28
Ask Guido about dropping the tank... he seems to like to do this quite often to install sumps and such! IIRC, you need to drop the rear and/or muffler. It's kind of a PITA, but doable in the driveway (though this is from a guy who has installed just about EVERYTHING in the apt complex parking lot...).
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86iroczwv
Sep 3, 2015 06:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
