What happens if rockers are on too tight?
Old May 26, 2001 | 11:34 AM
KW87GTA's Avatar
I am not sure if I have my rocker arms on too tight, I had to take 4 of them off to install my superram and I just put them back on to the recommened torque setting of 11lbs. I noticed they felt a little tighter than the others even though those all had 11lbs too. What will happen if they are too tight, and how do I tell? Thanks very much.
87 GTA 350 L98
K&N filter, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Gutted cat, removed emissions, Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant, 300 lbs lighter
Old May 26, 2001 | 11:41 AM
idrag2's Avatar
Well if they are on too tight you will either wear out the lobe on your cam or take out a lifter, bend a push rod. ect........but the way I adjust mine is pull off the valve cover start the car and one at a time loosen off the lock bolt till it starts ticking, then slowly tighten it up till it quits ticking, then go a 1\4 of a turn farther and they will be set.
later,
I Drag 2
Old May 26, 2001 | 09:07 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
your car will run real rough. 4 of your cylinders will be dead. When I loosen a couple of rockers I start the car and then I adjust them. I cut the top off of an old valve cover put it on so oil dosn't leak every were.
Ed1LE
Sep 30, 2018 09:14 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
